[mapguide-trac] #1939: When adding a new layer or map, the previous folder should be opened
MapGuide Open Source trac_mapguide at osgeo.org
Tue Jan 31 05:18:24 EST 2012
   Reporter:  hm           |       Owner:  jng
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:
  Component:  Maestro      |     Version:
   Severity:  trivial      |    Keywords:
External_id:               |
 When you add a new layer or add a layer to a map, it would be nice if the
 previous folder used were opened as default.
 Also when you save a feature source, the "current folder" should be
 updated. When you later add a new layer and need to select the feature
 source the application should put you in that folder (where you saved the
 feature source) as default.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1939>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
