[mapguide-trac] #1940: When testing a connection the previous error
message should be cleared
trac_mapguide at osgeo.org
Tue Jan 31 05:22:17 EST 2012
#1940: When testing a connection the previous error message should be cleared
Reporter: hm | Owner: jng
Type: enhancement | Status: new
Priority: low | Milestone:
Component: Maestro | Version:
Severity: trivial | Keywords:
External_id: |
When you test a connection and it fails an error message is displayed in
the text box next to the test button. When changing settings and pressing
test again, the same error message keeps displaying until the new test
returns either true or an error message. If the same error message is
displayed again then you are unsure if the test has run at all.
When pressing the test connection button the text box should be cleared as
the first thing, before running the actual test.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1940>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
