[mapguide-trac] #1941: Maestro - Add Layer to Map Enhancement
trac_mapguide at osgeo.org
Tue Jan 31 10:24:51 EST 2012
Reporter: crispinatime | Owner: jng
Type: enhancement | Status: new
Priority: low | Milestone: Maestro-4.1
Component: Maestro | Version:
Severity: trivial | Keywords:
External_id: |
When adding a new layer to a map, the layer comes in at the bottom of the
list/draworder. The default UI for editing the legend position allows the
layer to be repositioned but is is possible for the layer to remain at the
bottom of the draworder and yet appear to be in a group above other
layers. For example, adding a new layer to a map with a raster, the new
layer does not "appear" to be added on preview.
Suggestion 1) Always add new layers at the top of the list
Suggestion 2) Order the Maestro "Layers by Group" to be the same as the
MapGuide legend - ie show ungrouped layers *above* grouped layers as this
is how they will appear
Group / draworder / legend / map display is still confusing enough for me
so the more intuitive help to the novice the better
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1941>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
