[Mapguide-trac] [mapguide-trac] #2018: "Live" Map Definition editor
MapGuide Open Source trac_mapguide at osgeo.org
Mon Jun 4 08:13:34 PDT 2012
   Reporter:  jng          |       Owner:  jng
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:  Maestro-5.0
  Component:  Maestro      |     Version:
   Severity:  trivial      |    Keywords:
External_id:               |
Description changed by jng:
Old description:
> The introduction of the RuntimeMap viewer and the ability to go from Map
> Definition -> RuntimeMap -> Map Definition paves the way to add support
> for a new way to edit Map Definitions: A live Map Definition editor.
> Basically this will function in a way similar to the MapGuide 6.5 Author
> in terms of how maps are created.
> This will not replace the existing Map Definition editor, it will
> complement it. A new editor option will determine which one is used by
> default.
New description:
 This will not replace the existing Map Definition editor, it will be a
 standalone external tool
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2018#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
