[Mapguide-trac] [mapguide-trac] #2019: Support http/localnative connection creation with just session id
MapGuide Open Source trac_mapguide at osgeo.org
Mon Jun 4 08:50:26 PDT 2012
   Reporter:  jng          |       Owner:  jng
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:  Maestro-5.0
  Component:  Maestro      |     Version:
   Severity:  trivial      |    Keywords:
External_id:               |
 To avoid needing to spring up a login dialog if an external tool like
 MgCooker is invoked, we need to be able to support creating new
 IServerConnection instances (for http and LocalNative) by just passing in
 a session id.
 Such connections should support a SessionId connection property, and if
 such a property exists, to create a new connection from that session id.
 The caveat of this is that such connections will no longer have the
 ability to re-generate a new session if the current one's expired due to
 login information not being persisted. However this is a small price to
 pay
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2019>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
