[Mapguide-trac] [mapguide-trac] #2021: Maestro SVN build.bat does not copy OSGeo.MapGuide.MaestroAPI.Http.dll assembly in Release dir
MapGuide Open Source trac_mapguide at osgeo.org
Wed Jun 6 08:33:24 PDT 2012
   Reporter:  gabrimonfa  |       Owner:  jng
       Type:  defect      |      Status:  new
   Priority:  low         |   Milestone:
  Component:  Maestro     |     Version:
   Severity:  trivial     |    Keywords:
External_id:              |
 I'm using winXP SP3 and Maestro SVN r6735
 Doing a build.bat -a=clean and a build.bat, file
 OSGeo.MapGuide.MaestroAPI.Http.dll is not copied in out/Release directory.
 This leads to a "Failed to register provider Maestro.http" error trying to
 connect via http.
 Copying that file (and its .pcb) from sdk/bin solves the issue.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2021>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
