[Mapguide-trac] [mapguide-trac] #1983: MapTip command uses hard-coded button position
trac_mapguide at osgeo.org
Tue Jun 5 16:41:42 PDT 2012
Reporter: jng | Owner:
Type: defect | Status: reopened
Priority: low | Milestone: 2.4
Component: AJAX Viewer | Version:
Severity: trivial | Resolution:
Keywords: | External_id:
Changes (by trevorwekel):
* cc: trevorwekel (added)
* status: closed => reopened
* resolution: fixed =>
Comment:
If the toolbar is not present, the call to !GetMapTipButtons() will not
exist. A patch to ajaxmappane.templ is attached.
To reproduce, turn off the Map Pane Toolbar in any of the Sheboygan web
layouts. Before the patch, the map does not zoom to the correct extents
on initial load.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1983#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
