[Mapguide-trac] [mapguide-trac] #2040: Error in GetCommonParent
MapGuide Open Source trac_mapguide at osgeo.org
Mon Jun 25 05:28:38 PDT 2012
   Reporter:  hm       |       Owner:
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:
  Component:  General  |     Version:  2.1.0
   Severity:  trivial  |    Keywords:
External_id:           |
 In the file Maestro.Base\UI\SiteExplorer.cs in the method GetCommonParent
 there is an error:
        internal static string GetCommonParent(RepositoryItem[] data)
             if (data.Length > 0)
                 if (data.Length == 1)
                     if (data[0].IsFolder)
                         return data[0].ToString();
 The ToString will return the name of the object type
 "Maestro.Base.UI.RepositoryItem" and not the ResourceId "Library://../.."
 should be:
                         return data[0].ResourceId;
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2040>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
