[Mapguide-trac] [mapguide-trac] #2039: Maestro - Schema Versions and Updates
MapGuide Open Source trac_mapguide at osgeo.org
Mon Jun 25 09:44:47 PDT 2012
 Reporter:  crispinatime  |         Owner:  jng
     Type:  defect        |        Status:  closed
 Priority:  low           |     Milestone:  Maestro-5.0
Component:  Maestro       |       Version:
 Severity:  minor         |    Resolution:  fixed
 Keywords:                |   External_id:
Changes (by jng):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Fixed in trunk (r6812) and 4.0.x branch (r6813)
 Problem was due to insufficient default values for a new Simple Symbol
 Definition that satisfies the minimum content model requirements. For a
 text-based Simple Symbol Definition, this requires the textual content
 (empty string will suffice) and font name elements be specified.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2039#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
