[mapguide-trac] #1961: MgServer crashes by previewing a layer from
a Raster data connection without CS specified
trac_mapguide at osgeo.org
Mon Mar 5 00:47:58 EST 2012
#1961: MgServer crashes by previewing a layer from a Raster data connection
Reporter: wuma | Owner: wuma
Type: defect | Status: new
Priority: high | Milestone: 2.4
Component: Server | Version: 2.1.0
Severity: major | Keywords:
External_id: 1451912 |
It's reported by Autodesk QA:
steps:
1. Copy some raster data e.g. ECW, PNG, JPG, tif to linux OS, you can also
use attached one.
2. Create alias in site administrator.
3. In studio, connect to the linux server.
4. New data connection, select Raster provider, add the file attached,
save the data connection.
Note: test connection is correct.
5. Right click the data connection and choose New Layer function.
6. CLick Refresh button to preview the layer.
Result:
If the connected raster file is in format: ecw, png, jpg, tif, server will
crash.
If the format is bmp or cal, exception may happen, but server is not down.
Haven't tried other formats yet.
Preview layers generated through Load Procedure works well for all
formats.
Expectation:
Preview layers which are based on new connection correctly.
Regression: Y, fine in Reeses, but not sure in Jedi
Workaround: Y, load procedure
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1961>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
