[mapguide-trac] #1961: MgServer crashes by previewing a layer from a Raster data connection without CS specified
MapGuide Open Source trac_mapguide at osgeo.org
Thu Mar 8 21:20:31 EST 2012
   Reporter:  wuma     |       Owner:  wuma
       Type:  defect   |      Status:  new
   Priority:  high     |   Milestone:  2.4
  Component:  Server   |     Version:  2.1.0
   Severity:  major    |    Keywords:
External_id:  1451912  |
Comment(by wuma):
 Following line is executed in StylizeLayers() function:
 STRING layerWkt = layerCs->ToString();
 '''{{{layerCs}}}''' will be '''{{{NULL}}}''' if there is no CS or CS
 override specified for the feature source. Then '''{{{NULL}}}''' pointer
 exception will happen in above line. On Windows, there is a macro
 '''{{{MG_CATCH_AND_RELEASE()}}}''' to catch this exception and simply
 continue the logic.
 #define MG_CATCH_AND_RELEASE() \
 catch (MgException* e) \
 mgException = e; \
 catch (...) \
 However, on Linux, '''{{{NULL}}}''' pointer will lead to Segmentation
 Fault, which cannot be caught by '''{{{catch (...)}}}''' and will crash
 the application directly. So the pointer has to be verified before calling
 any methods of the pointer to avoid Segmentation Fault crash on Linux
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1961#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
