[mapguide-trac] #1967: Dropping layer into group doesn't work
MapGuide Open Source trac_mapguide at osgeo.org
Thu May 17 10:24:50 EDT 2012
 Reporter:  andrewd  |         Owner:  jng
     Type:  defect   |        Status:  closed
 Priority:  low      |     Milestone:  Maestro-5.0
Component:  Maestro  |       Version:  2.1.0
 Severity:  minor    |    Resolution:  fixed
 Keywords:           |   External_id:
Changes (by jng):
  * status:  reopened => closed
  * resolution:  => fixed
Comment:
 Fixed in trunk (r6657) and 4.0.x (r6659)
 Note that due to some quirks with the tree view we're using (it's not the
 stock WinForms treeview), you still need the drop target layer node to be
 highlighted or have the black horizontal line displaying for it to
 properly locate the parent group to add your dropped layer into.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1967#comment:7>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
