[Mapguide-trac] [mapguide-trac] #2107: Incorrect logic used to copy multiple resources across connections
MapGuide Open Source trac_mapguide at osgeo.org
Wed Sep 5 23:09:04 PDT 2012
   Reporter:  jng      |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  high     |   Milestone:  Maestro-4.0-maintenance
  Component:  Maestro  |     Version:
   Severity:  major    |    Keywords:
External_id:           |
 Consider 2 active connections that are laid out like so:
  - Connection A
    - Foo
      - Bar
  - Connection B
    - FolderA
      - Layers
        - Layer1,Layer2,...,LayerN
 If we copy Layer1,Layer2,...,LayerN from Connection B into
 Library://Foo/Bar/ on Connection A, we get the following layout on
 Connection A:
  - Foo
    - Bar
      - FolderA
        - Layers
 When instead we should be getting this folder structure instead:
  - Foo
    - Bar
 Basically when multiple resources are copied, their parentage is being
 retained when they should actually be discarded.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2107>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
