[Mapguide-trac] [mapguide-trac] #2116: Task Pane search functionality
trac_mapguide at osgeo.org
Thu Sep 13 12:55:12 PDT 2012
Reporter: bassonsh | Owner: jng
Type: enhancement | Status: new
Priority: medium | Milestone:
Component: Desktop API | Version: 2.4.0
Severity: minor | Keywords:
External_id: |
Comment(by bassonsh):
Ok maybe i'm approaching this the wrong way.
Why can i not just download the source code from
http://svn.osgeo.org/mapguide/trunk/MgDev/Desktop/, open the .sln file,
point the references to the right folder that contains those dll files,
build and run?? There are always so many things to fix up and i still cant
get it to compile?
Is there not a file that one can run after downloading the solution that
will check and basically 'correct' or setup the entire environment or
atleast an instruction document that tells you exactly what one will have
to fix up where (in rookie programmers language :-)) in order for the
solution to run?
Am i doing something wrong?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2116#comment:7>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
