[Mapguide-trac] [mapguide-trac] #2116: Task Pane search functionality
trac_mapguide at osgeo.org
Thu Sep 13 23:59:57 PDT 2012
Reporter: bassonsh | Owner: jng
Type: enhancement | Status: new
Priority: medium | Milestone:
Component: Desktop API | Version: 2.4.0
Severity: minor | Keywords:
External_id: |
Comment(by jng):
Sure, if you're only interested in building the .net bits you can indeed
just download the "Desktop" directory.
Unzip the latest mg-desktop binaries, and put them under {{{bin\Release}}}
and copy these assemblies to {{{bin\Assemblies}}}:
* OSGeo.MapGuide.Foundation.dll
* OSGeo.MapGuide.Geometry.dll
* OSGeo.MapGuide.PlatformBase.dll
* OSGeo.MapGuide.Desktop.dll
This will satisfy all the required references to build the .net projects.
But the way things are set up, it assumes the whole dependent stack of C++
libraries have been built up first (any dll not starting with
OSGeo.MapGuide is a C++ one), before you can even get to compile the mg-
desktop .net projects
1. FDO
2. All libraries under MgDev\Oem
3. All libraries under MgDev\Commmon
4. MgDesktop.dll
5. SWIG glue dlls (one that end with *UnmanagedApi.dll)
6. SWIG-generated .net wrapper assemblies
If you follow my above instructions. You can shortcut the above steps.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2116#comment:8>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
