[Mapguide-trac] [mapguide-trac] #2134: Cannot delete resource with different schema version
trac_mapguide at osgeo.org
Fri Sep 28 02:03:08 PDT 2012
Reporter: gBecker | Owner: jng
Type: defect | Status: new
Priority: low | Milestone: Maestro-5.0
Component: Maestro | Version: 2.4.0
Severity: minor | Keywords:
External_id: |
Comment(by jng):
Try this: Edit the raw XML header of that Web Layout and then save it
(without any changes) and then try deleting it again.
If you can then delete it afterwards, something has changed in the dbxml
regarding storage of resource header content because I've experienced this
same problem.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2134#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
