[Mapguide-trac] [mapguide-trac] #2134: Cannot delete resource with different schema version
MapGuide Open Source trac_mapguide at osgeo.org
Fri Sep 28 02:45:22 PDT 2012
   Reporter:  gBecker  |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  Maestro-5.0
  Component:  Maestro  |     Version:  2.4.0
   Severity:  minor    |    Keywords:
External_id:           |
Comment(by gBecker):
 After editing the raw XML header and saving it without changes I was able
 to delete the resource.
 As a sidenote: I did not delete the Libray from MapGuideOpenSource 2.4 RC1
 before installing  RC2. Does it matter?
 Second sidenote: I also recognised LayerDefinitions which I can't open
 anymore. Don't know if it is the same problem. Editing the raw XML header
 like above or upgrade the resource to the newest version doesn't take any
 effect! Error message is attached!
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2134#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
