[Mapguide-trac] [mapguide-trac] #2259: Support creating "legendless" themes
MapGuide Open Source trac_mapguide at osgeo.org
Tue Apr 9 08:36:31 PDT 2013
   Reporter:  jng          |       Owner:  jng
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:  Maestro-5.0
  Component:  Maestro      |     Version:
   Severity:  trivial      |    Keywords:
External_id:               |
Description changed by jng:
Old description:
> "legendless" themes are where a Layer Definition has one style rule, but
> whose line/point/area symbolization is driven by FDO stylization
> functions (namely the LOOKUP() expression function).
> Using the same theming UI, Maestro should support generating the
> equivalent LOOKUP() expression for certain style properties
New description:
 whose line/point/area symbolization is driven by FDO stylization functions
 (namely the LOOKUP() and RANGE() expression functions).
 equivalent LOOKUP() and/or RANGE() expression for certain style properties
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2259#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
