[Mapguide-trac] [mapguide-trac] #2327: Maestro: Consider similar option to Compile Full Dependency List that shows downstream dependencies
MapGuide Open Source trac_mapguide at osgeo.org
Wed Jul 31 10:07:11 PDT 2013
   Reporter:  jasonbirch   |       Owner:  jng
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:
  Component:  Maestro      |     Version:
   Severity:  trivial      |    Keywords:
External_id:               |
 Currently it appears that the Compile Full Dependency List option from the
 navigation window's context menu only shows items that resource depends
 on, not items that depend on it.
 I am currently in a case where I want to make a change to a Feature Source
 and want to see all of the Layers and Maps that will be affected by the
 change so I can make a test plan to ensure that the changes are not
 breaking.  Best I can do currently is screen shot the Layers list that
 comes out of the References tab on the feature source properties window
 and then run the same process for each of the Layers.
 I understand that there may be some complexity here, as there may be
 multiple layers that reference the same Map, and you'd want to remove
 duplicates from the list.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2327>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
