[Mapguide-trac] [mapguide-trac] #2326: Maestro: Consider providing a way to "jump" the resource tree to the currently selected tab
trac_mapguide at osgeo.org
Wed Jul 31 09:52:38 PDT 2013
Reporter: jasonbirch | Owner: jng
Type: enhancement | Status: new
Priority: low | Milestone:
Component: Maestro | Version:
Severity: trivial | Keywords:
External_id: |
Recently, I was drilling down from a Map Definition, through the Layer
Definition, to the Feature Source. I then wanted to view dependencies for
this Feature Source to see what else was using it and hit a bit of a wall.
The navigation tree was still stuck on the original Map Definition, and
the Resource ID for the Feature Source was only available in a tooltip
when hovering over the tab. The only way I could find to get to the
Feature Source in the navigation window so that I could access the context
menu actions (either Properties to view the References tab, or Compile
Full Dependency List) was to screenshot the tooltip then manually browse
to it.
I'm not sure what the answer to this is, whether it's an option on the
tab's context menu to "Jump to this Resource" or "Copy Resource ID", or a
graphical element somewhere near the top of the editor to allow you to
jump to the resource in the navigation tree, or maybe making more of the
navigation tree context menu actions available from within the editor?
Maybe I'm missing something?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2326>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
