[Mapguide-trac] [mapguide-trac] #2513: Split ObjectModels out to a	separate assembly
    trac_mapguide at osgeo.org
    Thu Dec 25 04:16:32 PST 2014
   Reporter:  jng          |       Owner:  jng
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:  Maestro-6.0
  Component:  Maestro      |     Version:
   Severity:  trivial      |    Keywords:
External_id:               |
 The Object Models that currently reside in the Maestro API and
 supplemental object model assemblies should be unified and put into a
 separate individual assembly to allow for use in other .net applications
 where there is a need to work with MapGuide resources in an object-
 oriented manner instead of raw XML
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2513>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
