[Mapguide-trac] [mapguide-trac] #2401: MgUnclassifiedException on every tile request
MapGuide Open Source trac_mapguide at osgeo.org
Fri Feb 14 06:21:38 PST 2014
   Reporter:  Gyufi         |       Owner:
       Type:  defect        |      Status:  new
   Priority:  medium        |   Milestone:  2.6
  Component:  Tile Service  |     Version:  2.5.0
   Severity:  blocker       |    Keywords:
External_id:                |
Comment(by Gyufi):
 Some more info and correction:
 IIS Application Pool recycling doesn't working nor MapGuide Windows
 Service restarting.
 The only solution is iisreset.
 We use 2 MapDefinition in an ApplicationDefinition.
 First using 94 base layers and 300 other layers with MSSQL and SDF
 datasources.
 Second using 48 base layers with DWF datasources.
 This error happens since second MapDefinition has added to the
 Note:
 If I send a request to the MapGuide to get a custom image (with custom
 width, height, dpi and scale) from the second Map (, that has DWF
 datasources), then MapGuide using DWF datasources instead of using the
 TileCache images.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2401#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
