[Mapguide-trac] [mapguide-trac] #2404: problem moving map group folders
MapGuide Open Source trac_mapguide at osgeo.org
Mon Feb 17 12:09:09 PST 2014
   Reporter:  andrewd  |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  Maestro-5.1
  Component:  Maestro  |     Version:  2.5.0
   Severity:  minor    |    Keywords:
External_id:           |
 This is a problem that's been in Maestro since the beginning. If you make
 a map and then make some groups, you'll find that you can't properly drag
 the groups. In fact, you can't even drag the layers to reorder them -
 despite the graphics which make it look like it will work. For layers you
 have to use the up/down buttons - which do nothing for groups.
 So, if you drag a group folder and want to put it above another group, it
 will drop it inside the top-most group, and there's no way to get it
 outside of that group without dragging it to another one. Even if you get
 the dividers in the right spot, it won't drop a group between other groups
 - it always puts it inside.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2404>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
