[Mapguide-trac] [mapguide-trac] #2446: Support adding default point/line/area styles for Advanced Stylization
trac_mapguide at osgeo.org
Mon May 12 12:00:29 PDT 2014
Reporter: jng | Owner: jng
Type: enhancement | Status: new
Priority: medium | Milestone: Maestro-6.0
Component: Maestro | Version:
Severity: major | Keywords:
External_id: |
Adding a new style for Advanced Stylization is a complicated process as it
involves needing to muck around with the symbol definition first before
you can play around with the composite symbolization settings.
To simplify this process, we should provide shortcuts to add a default
point/line/area composite style from which then the user can go straight
to tweaking the symbolization settings for the most general cases.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2446>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
