[Mapguide-trac] [mapguide-trac] #2542: Maestro not auto calculating extent with Base Layer Groups
trac_mapguide at osgeo.org
Fri Feb 27 02:14:35 PST 2015
Reporter: gBecker | Owner: jng
Type: defect | Status: new
Priority: low | Milestone: Maestro-6.0
Component: Maestro | Version: 2.6.0
Severity: trivial | Keywords:
External_id: |
Maestro doesn't auto calculate the map extent from layers in Base Layer
Groups.
It also doesn't set the map coordinate system.
This behaviour just belongs to maps without "regular" layers.
Additionally: pushing the button to set the extent "manually" also doesn't
work for those maps.
Tested with Maestro 6 on MGOS 2.6 and 3.0
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2542>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
