[Mapguide-trac] [mapguide-trac] #2543: Fusion Error when selecting a lot of objects in the map
trac_mapguide at osgeo.org
Fri Feb 27 04:33:06 PST 2015
Reporter: BSellke | Owner:
Type: defect | Status: new
Priority: high | Milestone:
Component: Fusion | Version: 2.6.0
Severity: critical | Keywords:
External_id: |
When unintentional selecting - for example instead of zooming - a big
area, this Fusion Error will be thrown, while working with MS-SQL-Server
2008 R2, MapGuide 2.6.0.8316.
Debugging in Firefox shows, that the error occurs in
'''Fusion.Widget.Select.execute''' when '''this.getMap().query(options)'''
is called...
Error Details:
Exception occurred in AJAX callback.
Message: JSON.parse: unexpected character at line 1 column 1 of the JSON
data
Location: http://mapguide.instance/mapguide/fusion/lib/fusionSF-
compressed.js (1)
Inner Stack:
window.Fusion.parseJSON at http://mapguide.instance/mapguide/fusion/lib
/fusionSF-compressed.js:1:7749
Fusion.Layers.MapGuide<.processSelectedExtendedFeatureInfo at http://mapguide.instance/mapguide/fusion/lib
/fusionSF-compressed.js:1:1522820
Fusion.Layers.MapGuide<.processExtendedFeatureInfo at http://mapguide.instance/mapguide/fusion/lib
/fusionSF-compressed.js:1:1522001
OpenLayers.Function.bind/<@http://mapguide.instance/mapguide/fusion/lib
/fusionSF-compressed.js:1:553242
OpenLayers.Ajax.Request<.respondToReadyState at http://mapguide.instance/mapguide/fusion/lib
/fusionSF-compressed.js:1:991757
OpenLayers.Ajax.Request<.onStateChange at http://mapguide.instance/mapguide/fusion/lib
/fusionSF-compressed.js:1:990544
Response: Dieser Fehler wird vom benutzerdefinierten Fehlermodul nicht
erkannt.
Stack Trace:
- window.Fusion.ajaxException at
http://mapguide.instance/mapguide/fusion/lib/fusionSF-compressed.js (line:
1)
- OpenLayers.Function.bind/< at
1)
- OpenLayers.Ajax.Request<.dispatchException at
1)
- OpenLayers.Ajax.Request<.respondToReadyState at
1)
- OpenLayers.Ajax.Request<.onStateChange at
1)
1)
Source:
http://mapguide.instance/mapguide/fusion/templates/mapguide/inexio/index.html?ApplicationDefinition=Library://inexio/inexio.ApplicationDefinition&locale=de
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2543>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
