[Mapguide-trac] [mapguide-trac] #2520: JenkinsCI/vagrant loose ends for 3.0 release cycle
MapGuide Open Source trac_mapguide at osgeo.org
Mon Jan 12 05:59:44 PST 2015
   Reporter:  jng           |       Owner:  jng
       Type:  task          |      Status:  new
   Priority:  low           |   Milestone:  3.0
  Component:  Build System  |     Version:
   Severity:  trivial       |    Keywords:
External_id:                |
 * Update trunk Fusion app.version to 3.0.0 in build.xml. The version is
 still 2.6.0 and is causing the buildtools package to not be copied to the
 build artifact directory
  * Run the mgserver test suite with a file parameter and configure a xUnit
 report task to report on the test output file
  * Also invoke the web tier test suite and log/report on its results. This
 requires us to be able to programatically configure up a MapGuide
 environment to run the tests in, so this item sort of depends on #2498
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2520>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
