[Mapguide-trac] [mapguide-trac] #2521: Improve the .net SWIG generated PINVOKE code for better ASP.net vNext support
MapGuide Open Source trac_mapguide at osgeo.org
Wed Jan 14 06:52:18 PST 2015
support
   Reporter:  jng      |       Owner:  jng
       Type:  task     |      Status:  new
   Priority:  low      |   Milestone:
  Component:  Web API  |     Version:
   Severity:  trivial  |    Keywords:
External_id:           |
 A cursory play-through of the current ASP.net vNext (5.0) bits suggests
 that it is possible to have the .net MapGuide API working on this new
 platform provided a few tweaks are made to the existing SWIG generated
 code.
 To open the possibility of ASP.net vNext Core CLR support for the .net
 MapGuide API wrapper, we should tweak the SWIG-generated PINVOKE code as
 follows:
  * Use generic Dictionary instead of Hashtable for class maps
  * {{{#if}}} guard .net type resolution code when throwing a .net
 exception or creating a .net proxy
  * Stub various classes and namespaces that are not supported in the
 ASP.net vNext profile. {{{#if}}} guard these stubs so they are skipped
 over when targeting the regular .net Framework.
  * Add {{{project.json}}} files to the DotNetApi component directories to
 allow easy building of aspnetcore50 targeted assemblies via {{{kpm
 build}}}
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2521>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
