[Mapguide-trac] [mapguide-trac] #2527: mapguide init script use log_daemon_msg and log_end_msg which are not defined in Centos 6
MapGuide Open Source trac_mapguide at osgeo.org
Tue Jan 20 05:57:49 PST 2015
defined in Centos 6
   Reporter:  gabrimonfa  |       Owner:
       Type:  defect      |      Status:  new
   Priority:  low         |   Milestone:
  Component:  General     |     Version:
   Severity:  trivial     |    Keywords:
External_id:              |
 Mapguide 3.0.0 centos 6 64bit.
 AFAIK log_daemon_msg and log_end_msg are not defined in Centos 6 even if
 lsb package is installed.
 A possible solution would be to define them at the beginning of mapguide
 script, so they are eventually overwritten by sourcing /lib/lsb/init-
 functions
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2527>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
