[Mapguide-trac] [mapguide-trac] #2571: Maestro: Cannot build custom LocalNativeProvider
MapGuide Open Source trac_mapguide at osgeo.org
Thu Sep 10 03:48:46 PDT 2015
   Reporter:  gBecker  |      Owner:  jng
       Type:  defect   |     Status:  new
   Priority:  high     |  Milestone:  Maestro-6.0
  Component:  Maestro  |    Version:  3.0.0
   Severity:  major    |   Keywords:
External ID:           |
 Hi Jackie,
 I'm trying to build a custom LocalNativeProvider for the latest
 MapGuideOpenSource Version (3.0) using the LocalNativeProvider-Tool from
 Maestro (build from trunk). As you can guess: it doesn't work! The custom
 LocalNativeProvider isn't build!
 First, the tool tries to sign the dll's located in the "MapGuide .net
 assemblies directory" wich works, except for the none existing
 MapGuideDotNetApi.dll. I do not think that this is the reason for not
 building the custom provider, cause this file doesn't already exists in
 former versions of MGOS.
 I think the root cause is the the tool can't find a specific dll named
 "NetTopologySuite.Merged.dll".
 You can see it in the log:
 Validating input parameters
 .net Framework 4.0  directory found
 MapGuide .net assemblies directory found
 SDK binaries directory exists
 Cleaned output directory: C:\Users\gunter.becker.CSO\Documents\Visual
 Studio 2015\Projects\MAESTRO\SDK\LocalNativeProvider\Bin
 Cleaned lib directory: C:\Users\gunter.becker.CSO\Documents\Visual Studio
 2015\Projects\MAESTRO\SDK\LocalNativeProvider\Lib\MapGuide
 Copying MapGuide dlls to lib
 Copied: C:\Program
 Files\OSGeo\MapGuide3.0\Web\www\mapviewernet\bin\ACE.dll
 Copied: C:\Program
 Files\OSGeo\MapGuide3.0\Web\www\mapviewernet\bin\FoundationUnmanagedApi.dll
 Copied: C:\Program
 Files\OSGeo\MapGuide3.0\Web\www\mapviewernet\bin\GeometryUnmanagedApi.dll
 Copied: C:\Program
 Files\OSGeo\MapGuide3.0\Web\www\mapviewernet\bin\GEOS.dll
 Copied: C:\Program
 Files\OSGeo\MapGuide3.0\Web\www\mapviewernet\bin\lib_json.dll
 Copied: C:\Program
 Files\OSGeo\MapGuide3.0\Web\www\mapviewernet\bin\MapGuideCommonUnmanagedApi.dll
 Copied: C:\Program
 Files\OSGeo\MapGuide3.0\Web\www\mapviewernet\bin\MgFoundation.dll
 Copied: C:\Program
 Files\OSGeo\MapGuide3.0\Web\www\mapviewernet\bin\MgGeometry.dll
 Copied: C:\Program
 Files\OSGeo\MapGuide3.0\Web\www\mapviewernet\bin\MgHttpHandler.dll
 Copied: C:\Program
 Files\OSGeo\MapGuide3.0\Web\www\mapviewernet\bin\MgMapGuideCommon.dll
 Copied: C:\Program
 Files\OSGeo\MapGuide3.0\Web\www\mapviewernet\bin\MgMdfModel.dll
 Copied: C:\Program
 Files\OSGeo\MapGuide3.0\Web\www\mapviewernet\bin\MgMdfParser.dll
 Copied: C:\Program
 Files\OSGeo\MapGuide3.0\Web\www\mapviewernet\bin\MgPlatformBase.dll
 Copied: C:\Program
 Files\OSGeo\MapGuide3.0\Web\www\mapviewernet\bin\MgWebApp.dll
 Copied: C:\Program
 Files\OSGeo\MapGuide3.0\Web\www\mapviewernet\bin\MgWebSupport.dll
 Copied: C:\Program
 Files\OSGeo\MapGuide3.0\Web\www\mapviewernet\bin\OSGeo.MapGuide.Foundation.dll
 Copied: C:\Program
 Files\OSGeo\MapGuide3.0\Web\www\mapviewernet\bin\OSGeo.MapGuide.Geometry.dll
 Copied: C:\Program
 Files\OSGeo\MapGuide3.0\Web\www\mapviewernet\bin\OSGeo.MapGuide.MapGuideCommon.dll
 Copied: C:\Program
 Files\OSGeo\MapGuide3.0\Web\www\mapviewernet\bin\OSGeo.MapGuide.PlatformBase.dll
 Copied: C:\Program
 Files\OSGeo\MapGuide3.0\Web\www\mapviewernet\bin\OSGeo.MapGuide.Web.dll
 Copied: C:\Program
 Files\OSGeo\MapGuide3.0\Web\www\mapviewernet\bin\PlatformBaseUnmanagedApi.dll
 Copied: C:\Program
 Files\OSGeo\MapGuide3.0\Web\www\mapviewernet\bin\WebUnmanagedApi.dll
 Copied: C:\Program Files\OSGeo\MapGuide3.0\Web\www\mapviewernet\bin
 \xerces-c_3_1mg.dll
 Signing MapGuide assemblies
 Target Framework: 2.0
 Detecting tools...Done
 Compiler: C:\Windows\Microsoft.NET\Framework64\v2.0.50727\ilasm.exe
 Decompiler: C:\Program Files (x86)\Microsoft
 SDKs\Windows\v7.0A\Bin\x64\ildasm.exe
 Creating Backup folder...Done
 Backing up original DLL files.
 [WARNING]: Could not find file to backup (MapGuideDotNetApi.dll)
 Copying OSGeo.MapGuide.Foundation.dll...Done
 Copying OSGeo.MapGuide.Geometry.dll...Done
 Copying OSGeo.MapGuide.MapGuideCommon.dll...Done
 Copying OSGeo.MapGuide.PlatformBase.dll...Done
 Copying OSGeo.MapGuide.Web.dll...Done
 [WARNING]: Could not find file to decompilation (MapGuideDotNetApi.dll)
 Decompiling: OSGeo.MapGuide.Foundation.dll...Done
 Decompiling: OSGeo.MapGuide.Geometry.dll...Done
 Decompiling: OSGeo.MapGuide.MapGuideCommon.dll...Done
 Decompiling: OSGeo.MapGuide.PlatformBase.dll...Done
 Decompiling: OSGeo.MapGuide.Web.dll...Done
 Deleting MapGuideDotNetApi.dll...done
 Deleting OSGeo.MapGuide.Foundation.dll...done
 Deleting OSGeo.MapGuide.Geometry.dll...done
 Deleting OSGeo.MapGuide.MapGuideCommon.dll...done
 Deleting OSGeo.MapGuide.PlatformBase.dll...done
 Deleting OSGeo.MapGuide.Web.dll...done
 Fixing: OSGeo.MapGuide.Web.il
   Added key to section: .assembly extern /*23000002*/
 osgeo.mapguide.foundation
   Added key to section: .assembly extern /*23000003*/
 osgeo.mapguide.platformbase
   Added key to section: .assembly extern /*23000004*/
 osgeo.mapguide.geometry
 Compiling: OSGeo.MapGuide.Web.il...Done
 Fixing: OSGeo.MapGuide.PlatformBase.il
   Added key to section: .assembly extern /*23000001*/
 Compiling: OSGeo.MapGuide.PlatformBase.il...Done
 Fixing: OSGeo.MapGuide.MapGuideCommon.il
 Compiling: OSGeo.MapGuide.MapGuideCommon.il...Done
 Fixing: OSGeo.MapGuide.Geometry.il
 Compiling: OSGeo.MapGuide.Geometry.il...Done
 Fixing: OSGeo.MapGuide.Foundation.il
 Compiling: OSGeo.MapGuide.Foundation.il...Done
 [WARNING]: Cannot find IL file to fix (MapGuideDotNetApi.il)
 [WARNING]: No IL file to compile (MapGuideDotNetApi.il)
 Cleanup...Done
 All OSGeo files has been signed.
 Write out AssemblyInfo.cs
 http://xkcd.com/303/ - OSGeo.MapGuide.MaestroAPI.Native-3.0.0.dll
 Microsoft (R) Visual C# Compiler version 4.6.0079.0
 for C# 5
 Copyright (C) Microsoft Corporation. All rights reserved.
 This compiler is provided as part of the Microsoft (R) .NET Framework, but
 only supports language versions up to C# 5, which is no longer the latest
 version. For compilers that support newer versions of the C# programming
 language, see http://go.microsoft.com/fwlink/?LinkID=533240
 error CS0006: Die Metadatendatei
 'C:\Users\gunter.becker.CSO\Documents\Visual Studio
 2015\Projects\MAESTRO\SDK\LocalNativeProvider\..\Bin\NetTopologySuite.Merged.dll'
 konnte nicht gefunden werden.
 csc.exe returned 1
 Build SUCCESS
 Thanks, Gunter
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2571>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
