[Mapguide-trac] [mapguide-trac] #2820: CMake: Don't link libjpeg in MgRenderers
MapGuide Open Source trac_mapguide at osgeo.org
Thu Sep 10 11:13:39 PDT 2020
   Reporter:  jng           |      Owner:  jng
       Type:  defect        |     Status:  assigned
   Priority:  low           |  Milestone:  4.0
  Component:  Build System  |    Version:
   Severity:  trivial       |   Keywords:
External ID:                |
 I saw this interesting message in making the deb packages:
 dpkg-shlibdeps: warning: package could avoid a useless dependency if
 /tmp/work/build_area/mapguide/mg_deb/debian/mapguidecommon/usr/local/mapguideopensource-4.0.0/lib64/libMgRenderers.so
 /tmp/work/build_area/mapguide/mg_deb/debian/mapguidecommon/usr/local/mapguideopensource-4.0.0/lib64/libMgRenderers-4.0.0.so
 were not linked against libjpeg.so.8 (they use none of the library's
 symbols)
 If we're linking to libjpeg, we can remove it. If MgRenderers was the only
 one trying to link to libjpeg, we can also stop finding it as well
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2820>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
