[Mapguide-trac] [mapguide-trac] #2820: CMake: Don't link libjpeg in MgRenderers
trac_mapguide at osgeo.org
Thu Sep 10 11:13:56 PDT 2020
Reporter: jng | Owner: jng
Type: defect | Status: assigned
Priority: low | Milestone: 4.0
Component: Build System | Version:
Severity: trivial | Resolution:
Keywords: | External ID:
Description changed by jng:
Old description:
> I saw this interesting message in making the deb packages:
> dpkg-shlibdeps: warning: package could avoid a useless dependency if
> /tmp/work/build_area/mapguide/mg_deb/debian/mapguidecommon/usr/local/mapguideopensource-4.0.0/lib64/libMgRenderers.so
> /tmp/work/build_area/mapguide/mg_deb/debian/mapguidecommon/usr/local/mapguideopensource-4.0.0/lib64/libMgRenderers-4.0.0.so
> were not linked against libjpeg.so.8 (they use none of the library's
> symbols)
> If we're linking to libjpeg, we can remove it. If MgRenderers was the
> only one trying to link to libjpeg, we can also stop finding it as well
New description:
symbols)
If we're linking to libjpeg, we can remove it. If MgRenderers was the only
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2820#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
