[Mapguide-trac] [mapguide-trac] #2847: MgInstantSetup: Needs flag to make 64-bit IIS application pool
trac_mapguide at osgeo.org
Tue Aug 9 06:29:58 PDT 2022
Reporter: jng | Owner: jng
Type: defect | Status: assigned
Priority: low | Milestone: 4.0
Component: Installer | Version:
Severity: trivial | Keywords:
External ID: |
Right now if setting up for IIS, the InstantSetup tool does not disable
the enable32BitAppOnWin64 setting on the application pool it creates.
This will cause the mapagent handler to fail because IIS will be treating
it as a 32-bit application
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2847>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
