[Mapguide-trac] [mapguide-trac] #2847: MgInstantSetup: Needs flag to make 64-bit IIS application pool
MapGuide Open Source trac_mapguide at osgeo.org
Tue Aug 9 07:19:27 PDT 2022
 Reporter:  jng        |        Owner:  jng
     Type:  defect     |       Status:  closed
 Priority:  low        |    Milestone:  4.0
Component:  Installer  |      Version:
 Severity:  trivial    |   Resolution:  fixed
 Keywords:             |  External ID:
Changes (by jng):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"9952" 9952]:
 {{{#!CommitTicketReference repository="" revision="9952"
 Add new checkbox to explicitly state whether the IIS application pool to
 be created needs to support 32-bit applications or not. It is unchecked by
 default meaning that we assume by default we are doing an instant setup
 for a 64-bit MapGuide installation.
 Fixes #2847
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2847#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
