[Mapguide-trac] [mapguide-trac] #2861: Server test suite should output all generated files under a top-level "Results" directory
MapGuide Open Source trac_mapguide at osgeo.org
Sat Feb 4 02:39:20 PST 2023
"Results" directory
   Reporter:  jng      |      Owner:  jng
       Type:  task     |     Status:  assigned
   Priority:  low      |  Milestone:  4.0
  Component:  Server   |    Version:
   Severity:  trivial  |   Keywords:
External ID:           |
 Having all the generated files under a top-level `Results` directory paves
 the way in the future to easily do image-diff comparison of image results
 easily against a baseline set of results for more objective verification
 of image rendering results.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2861>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
