[Mapguide-trac] [mapguide-trac] #2861: Server test suite should output all generated files under a top-level "Results" directory
MapGuide Open Source trac_mapguide at osgeo.org
Thu Feb 9 03:58:32 PST 2023
"Results" directory
 Reporter:  jng      |        Owner:  jng
     Type:  task     |       Status:  closed
 Priority:  low      |    Milestone:  4.0
Component:  Server   |      Version:
 Severity:  trivial  |   Resolution:  fixed
 Keywords:           |  External ID:
Changes (by jng):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"10027" 10027]:
 {{{#!CommitTicketReference repository="" revision="10027"
 Store all baseline results under a top-level "Baselines" directory and all
 results under a top-level "Results" directory
 Fixes #2861
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2861#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
