[Mapguide-trac] [mapguide-trac] #2862: React viewer status bar selection display do not incorporate programmatic selections, only mouse operations selections
trac_mapguide at osgeo.org
Tue Feb 7 05:41:33 PST 2023
Reporter: jnel | Owner: (none)
Type: defect | Status: new
Priority: high | Milestone:
Component: General | Version:
Severity: major | Resolution:
Keywords: React Selection | External ID:
Comment (by jng):
Before I close this ticket and relocate the contents to the mapguide-
react-layout github repo, can I just check how your operation is doing
that selection?
Are you hitting some server-side PHP/.net/Java code that does an
`MgSelection` update and then emits some JS to refresh the map?
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2862#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
