[Mapguide-trac] [mapguide-trac] #772: Multiline text displays within a region as left justification only
trac_mapguide at osgeo.org
Thu Feb 9 02:44:19 PST 2023
Reporter: zspitzer | Owner: jng
Type: defect | Status: closed
Priority: medium | Milestone: 4.0
Component: Rendering Service | Version: 2.4.0
Severity: minor | Resolution: fixed
Keywords: | External ID:
Changes (by jng):
* owner: (none) => jng
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"10026" 10026]:
{{{#!CommitTicketReference repository="" revision="10026"
Implement MapGuide RFC 186
Fixes #772
Merged revision(s) 10023-10025 from sandbox/jng/basic_label_justification:
#772: Fix up element documentation
#772: Add basic stylization support for justification of labels. This
support already existed in the rendering/stylization engine. The
justification setting simply never surfaced to any supported element in
the current Layer Definition XML schema, so it always defaulted to left
justification. This setting will be most impactful when dealing with
multi-line feature labels where such a setting becomes important.
New rendering service tests have been added to exercise the various label
justification settings. Manually inspecting the rendered results verifies
the new justification setting is being respected.
Since we're here, we are also cleaning up the current v4.0.0 schema by
making the previously introduced IncludeBoundsForSelectedFeatures element
optional.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/772#comment:11>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
