[Mapguide-trac] [mapguide-trac] #2865: MgTileSeeder XYZ TileSet generation fails: minx not in range of [-180, 180]
MapGuide Open Source trac_mapguide at osgeo.org
Thu Mar 23 22:56:26 PDT 2023
   Reporter:  Percy      |      Owner:  (none)
       Type:  defect     |     Status:  new
   Priority:  high       |  Milestone:
  Component:  Tile       |    Version:
  Service                |   Keywords:  MgTileSeeder XYZ TileSet: minx not
   Severity:  blocker    |  in range of [-180, 180]
External ID:             |
 When generating XYZ TileSets the generation/transformation fails when minx
 exceeds [-180, 180]
 It may be related to the MapGuide Maestro fix "LL84 bounding box
 transformation failing if it exceeds [-180, -90, 180, 90]" in Release
 6.0m11 (6.0.0.473)
 Operating System - Windows Server 2022
 IIS - 10.0.20348.1
 MapGuide 4.0.0 Preview 4
 MapGuide Maestro Release 6.0m11 (6.0.0.473)
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2865>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
