[Mapguide-trac] [mapguide-trac] #2865: MgTileSeeder XYZ TileSet generation fails: minx not in range of [-180, 180]
MapGuide Open Source trac_mapguide at osgeo.org
Thu Mar 23 22:57:11 PDT 2023
 Reporter:  Percy                                |        Owner:  (none)
     Type:  defect                               |       Status:  new
 Priority:  high                                 |    Milestone:
Component:  Tile Service                         |      Version:
 Severity:  blocker                              |   Resolution:
 Keywords:  MgTileSeeder XYZ TileSet: minx not   |  External ID:
  in range of [-180, 180]                        |
Description changed by Percy:
Old description:
> When generating XYZ TileSets the generation/transformation fails when
> minx exceeds [-180, 180]
> It may be related to the MapGuide Maestro fix "LL84 bounding box
> transformation failing if it exceeds [-180, -90, 180, 90]" in Release
> 6.0m11 (6.0.0.473)
> Operating System - Windows Server 2022
> IIS - 10.0.20348.1
> MapGuide 4.0.0 Preview 4
> MapGuide Maestro Release 6.0m11 (6.0.0.473)
New description:
 When generating XYZ TileSets the generation/transformation fails when minx
 exceeds [-180, 180]
 6.0m11 (6.0.0.473)
 IIS - 10.0.20348.1
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2865#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
