[mapguide-users] RE: RE: MapGuide OS with Google Earth
Willem Schwarte willem at giskit.nl
Tue Apr 11 16:23:14 EDT 2006
Andy,
Could I have your shapes, so I can test this with my server?
Thanks.
Willem Schwarte
-----Oorspronkelijk bericht-----
Van: Traian Stanev [mailto:traian.stanev at autodesk.com]
Verzonden: dinsdag 11 april 2006 17:45
Aan: users at mapguide.osgeo.org
Onderwerp: RE: [mapguide-users] RE: RE: MapGuide OS with Google Earth
I think it's not limited to PHP, but it may not happen with all files,
or it might also depend on which build of the server/web you are using.
I am not sure yet.
Traian
-----Original Message-----
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Tuesday, April 11, 2006 11:37 AM
Subject: [mapguide-users] RE: RE: MapGuide OS with Google Earth
Is this a limitation of the PHP web extensions only?  I am using the
.NET web
extensions and I have similar functionality programmed in .NET
(https://mapguide.osgeo.org/livegallery.html) and can display well over
100
features in the KML (KMZ in my case).  I also just checked with some
older
PHP code based on the same code you are using from Jason Birch and I see
the
same thing, well over 100 features in the KML.  In this case, it is
still
using the .NET web extensions but just PHP accessing the API.
View this message in context:
http://www.nabble.com/RE%3A-MapGuide-OS-with-Google-Earth-t1425312.html#
a3864292
Sent from the OSGeo MapGuide forum at Nabble.com.
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users mailing list
