[mapguide-users] RE: RE: MapGuide OS with Google Earth
Andy Morsell
amorsell at spatialgis.com
Thu Apr 13 11:45:32 EDT 2006
That's great about reading features quicker via the API. I had to
generalize almost all of my data in order to avoid Google Earth timeout
issues waiting for the network link to respond while the code was
processing. That should help partially solve that problem.
Regarding MapGuide Server versions, I am using theRC1 build from last week,
but never saw the number of feature limitation in prior builds either.
Andy
-----Original Message-----
From: Traian Stanev [mailto:traian.stanev at autodesk.com]
Sent: Thursday, April 13, 2006 5:49 AM
Subject: RE: [mapguide-users] RE: RE: MapGuide OS with Google Earth
I just checked in a fix for this (issue MG213). You guys must be using
different builds of MapGuide if one of you is seeing the problem and the
other isn't, since it was not a random or timing-dependent thing.
On the bright side, while messing with that code path I also made it more
than twice faster to read features via this API (as measured against SDF
sources with default server settings), so reading features for Google Earth
purposes should now be significantly faster.
Traian
Sent: Thursday, April 13, 2006 3:42 AM
Well... in studio I can see a lot of lines, but in Google Earth the export
is minimal, check the pictures...
The demo on osgeo is very nice!
Willem
-----Oorspronkelijk bericht-----
Van: Andy Morsell [mailto:amorsell at spatialgis.com]
Verzonden: dinsdag 11 april 2006 22:42
Aan: users at mapguide.osgeo.org
Onderwerp: RE: [mapguide-users] RE: RE: MapGuide OS with Google Earth
Willem,
I have copied a MapGuide package to my FTP site. You can download it with
anonymous access from ftp://mapguide.spatialgis.com/public/GE_demo_data.mgp
I hope this helps track down the problem.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
Sent: Tuesday, April 11, 2006 1:23 PM
Andy,
Could I have your shapes, so I can test this with my server?
Thanks.
Willem Schwarte
Van: Traian Stanev [mailto:traian.stanev at autodesk.com]
Verzonden: dinsdag 11 april 2006 17:45
I think it's not limited to PHP, but it may not happen with all files, or it
might also depend on which build of the server/web you are using.
I am not sure yet.
Traian
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Tuesday, April 11, 2006 11:37 AM
Subject: [mapguide-users] RE: RE: MapGuide OS with Google Earth
Is this a limitation of the PHP web extensions only? I am using the
.NET web
extensions and I have similar functionality programmed in .NET
(https://mapguide.osgeo.org/livegallery.html) and can display well over
100
features in the KML (KMZ in my case). I also just checked with some
older
PHP code based on the same code you are using from Jason Birch and I see
the
same thing, well over 100 features in the KML. In this case, it is
still
using the .NET web extensions but just PHP accessing the API.
View this message in context:
http://www.nabble.com/RE%3A-MapGuide-OS-with-Google-Earth-t1425312.html#
a3864292
Sent from the OSGeo MapGuide forum at Nabble.com.
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users
