[mapguide-users] MapGuide for an AVL app?
Max Brown maxbrown3 at gmail.com
Thu Apr 20 05:04:58 EDT 2006
Thanks Andy for the info, very useful for my evaluation, I also have a few
other clarifications : must I use Autodesk Mapguide Studio to develop the
app? the preview version doesn't support anything much (specially database
connectivity). So is there an alternative to MGS or preferably an Open
Source option :).
Do you know any other similar apps developed using MGOS? where I might be
able to look at a sample to get an idea.
On 4/20/06, Andy Morsell <amorsell at spatialgis.com> wrote:
>  Yes, it would work well.  As part of your system, you will be feeding a
> database with point information (historic and current) about vehicle
> locations.  You would define some queries in that database to extract only
> the latest time-based position.  Then, in MGOS, you would point your layer
> definition(s) to these queries where the symbols would be drawn directly
> from the x,y data in the database using the FDO ODBC data provider.  A
> little programming using the MGOS API would be necessary to refresh the
> layers at the desired time interval, be it every 10 seconds or every 5
> minutes or whatever.  If the latest point data has changed since the last
> refresh, then the vehicle symbols will shift accordingly.  Or, you might be
> able to write a trigger that would call a stored procedure if new point data
> is added and then force a refresh from the server-side.
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com <http://www.spatialgis.com/>
> *From:* Max Brown [mailto:maxbrown3 at gmail.com]
> *Sent:* Wednesday, April 19, 2006 10:10 PM
> *To:* users at mapguide.osgeo.org
> *Subject:* [mapguide-users] MapGuide for an AVL app?
>  Hello,
> I'm currently evaluating web based mapping software for an AVL system.
> Could somebody let me know if Mapguide OS is a suitable dev platform to
> develop a web based Vehicle tracking system. Is it possible to dynamically
> plot coordinates on the MapGuide OS platoform.
> Thx
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060420/a82684d8/attachment.html
More information about the Mapguide-users mailing list
