[mapguide-users] problems with invoke URL
Butler, Juan P jpbutler at co.pinellas.fl.us
Mon Apr 24 11:25:51 EDT 2006
OK...Thanks for the info.  I haven't had an issue like this, but I've
had to restart the MG service, never to reboot the machine.   I'll
probably go with a test box for now.  Just a hassle to find one and
setup.
- Juan
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Monday, April 24, 2006 11:15 AM
Subject: RE: [mapguide-users] problems with invoke URL
You may want to hold off on that for a while if you have a SLA on your
production box.  Although the installs do not appear to conflict, I've
had a couple MGOS crashes that have required a server reboot, reducing
the uptime on the production server.
Jason
From: Butler, Juan P [mailto:jpbutler at co.pinellas.fl.us]
Sent: Monday, April 24, 2006 07:40
Really...Hmm.  I was thinking about putting the test stuff I've done on
a separate machine (which would be a little bit of a pain), but maybe
I'll put it beside my existing Mapguide production box.   Much easier.
- Juan
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Monday, April 24, 2006 12:42 AM
I just wanted to mention that there doesn't seem to be any conflicts
between running MapGuide 6.5 and MapGuide Open Source.  I run both on
more than one computer and have not had any problems related to the side
by side installs.
Andy
Sent: Saturday, April 22, 2006 12:55 PM
I think you are confused.   We are testing Mapguide Open Source which is
a totally different version than Mapguide 6.x.   You should put the new
version of Open Source on a machine that doesn't have previous versions
of Mapguide.   You will need to download Mapguide Studio for your "map
authoring" and data loads.
Also, the .NET version of the Open Source install requires .NET
framework 2.0.  This is the reson for your error.
- Juan
From: sukalyan chakraborty [mailto:chakraborty.sarkar at gmail.com]
Sent: Sat 4/22/2006 1:06 AM
Subject: Re: [mapguide-users] problems with invoke URL
yes i'm using mapguide 6.5
when i attempt to run it from
http://localhost/mapguide/mapviewernet/ajaxviewerabout.aspx then get the
error
Compilation Error
Description: An error occurred during the compilation of a resource
required to service this request. Please review the following specific
error details and modify your source code appropriately.
Compiler Error Message: CS0246: The type or namespace name 'OSGeo' could
not be found (are you missing a using directive or an assembly
reference?)
Source Error:
Line 21: <%@ Import Namespace="System.Web" %>
Line 22: <%@ Import Namespace="System.Globalization" %>
Line 23: <%@ Import Namespace="OSGeo.MapGuide" %>
Line 24:
Line 25: <!-- #Include File="common.aspx -->
Source File: C:\Program
Files\MapGuideOpenSource\WebServerExtensions\www\mapviewernet\ajaxviewer
about.aspx    Line: 23
On 4/21/06, Butler, Juan P <jpbutler at co.pinellas.fl.us> wrote:
Are you using Mapguide 6.5?   Not sure why you would be posting here for
.mwf file.   The new Mapguide Open Source no longer uses this format.
If you are using Mapguide 6.5, just use Mapguide Author.
Juan Butler - Senior Programmer/Analyst
GIS Applications
Pinellas County Information Systems
jpbutler at pinellascounty.org
From: sukalyan chakraborty [mailto: chakraborty.sarkar at gmail.com]
Sent: Friday, April 21, 2006 6:57 AM
can u tell me please how can i create the .mwf file?
On 4/20/06, shailesh < shailesh at simplexindia.com
<mailto:shailesh at simplexindia.com> > wrote:
hi all.
i have a problem with invoke url command, when i assign the URL TO OPEN
..\dotnetviewersample\navigatetask.aspx
it shows me page cannot be dispalyed
however when i type
http:\\localhost\mapguide\dotnetviewersample\navigatetask.aspx
in URL TO OPEN it works
i also tried something like c:\1.html after creating a file in C:\ even
that does not work
and also when i tested my application whihc is on the webserver
it tried typing the URL to invoke
http:\\myipaddress\mapguide\dotnetviewersample\navigatetask.aspx i was
unable to get
(i tried this because the localhost path was working onmy local machine)
need help on the correct way to write the URL to Invoke "
thanks
--------------------------------------------------------------------- To
unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org For additional
commands, e-mail: users-help at mapguide.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060424/b6fe5a51/attachment.html
More information about the Mapguide-users mailing list
