[mapguide-users] Any work being done on fixing MS IE KB912945
Walt Welton-Lair walt.welton-lair at autodesk.com
Wed Apr 26 15:48:08 EDT 2006
It's already been fixed in MapGuide.  There was an artifact (you can
search for it :->).
The next release of DWF Viewer will also address this.
Walt
  _____
Sent: Wednesday, April 26, 2006 3:46 PM
Subject: [mapguide-users] Any work being done on fixing MS IE KB912945
Microsoft has deployed a "security" patch which forces you to "click to
activate" any ActiveX control before you can use it. It is exceptionally
annoying. Naturally, this affects the DWF Viewer.  It also affects the
legend and property pane.  If you havent already dealt with it, you can
see info about it here
http://www.microsoft.com/technet/security/advisory/912945.mspx
<http://www.microsoft.com/technet/security/advisory/912945.mspx> . It is
also worth looking at http://support.microsoft.com/kb/912945
<http://support.microsoft.com/kb/912945>
Has anyone looked at implementing the workaround? Can someone log this
as an artifact?
--Joel
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060426/3b9676f7/attachment.html
More information about the Mapguide-users mailing list
