[mapguide-users] Join Features
Dave Wilson dave.wilson at autodesk.com
Wed Aug 2 10:58:09 EDT 2006
In the layer you must change your feature class to the new one defined
in the join. You should then see the property list change to show the
additional columns.
Leave the geometry as the orginal geometry property for the SDF. If you
select the new geometry you will get nothing.
Dave
  _____
From: Farzad Ghavam [mailto:farzadghavam at yahoo.co.uk]
Sent: Wednesday, August 02, 2006 7:02 AM
Subject: [mapguide-users] Join Features
Hi to all,
I'm sorry for my english,
I have a problem with Join Feature section by following steps:
   1-Load a SDF file and create a layer by this ( Named : WorldSDF )
   2-create a new connection with ODBC-Table in an Access DB file (
Named : WorldDB ) and get 'Successful connection' message after test
connection.
   3-in 'Join with other feature sources(optional)' create a new
extended feature class and connect 'WorldSDF' and 'WorldDB' by those
fileds.
   4-create a layer by new feature class ( NewLayer ) but when preview
,there isn't any data
please help me.
thanks
farzad
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060802/0ce0fe7d/attachment.html
More information about the Mapguide-users mailing list
