[mapguide-users] Re: Access and Mapguide
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Thu Aug 3 09:39:02 EDT 2006
Good to hear that you figured that out....not a good solution for my
case though, since my key isn't a number (it's alphanumeric). I still
haven't played with it yet though.....I'm in no rush because as you'll
likely find out, a point layer from an Access database is pretty slow. I
ended up getting fed up with the speed and just made a shape file from
my database and used that. I'm guessing that linking my other data to
that shape file will be re-introducing that poor performance, so that's
why I haven't been really focusing on that just yet.
I can definately verify that doubles work though. That's what mine are,
and I got it working (though, like I said, it's pretty slow for me).
There was a thread on here a few days ago about this....someone was
having problems, and for them, it was because of regional settings in
windows (though, changing the regional settings didn't matter...they had
to edit a file or something to make it work). If you're in North America
though, that shouldn't be the problem.
Andrew
Jean-François Laflèche wrote:
> I have found a solution to this problem! It seems that the best way
> to join an access database to an sdf file is by joining a key auto
> number (long interger type) column from the database, to the
> corresponding key field from the sdf. I hope this will work for
> others and will help out all those that have come accross the same
> problem.
> However, it would be too great if all my problems were solved. The
> problem that I've come accross this time is when trying to create a
> point layer using both a feature class and the geometry from an access
> database. I suspect the problem to be purely in terms of the format
> used for the coordinates (I use double, as the samples seem to use
> this as well). However, nothing shows up. If anyone knows how to do
> this, it would be greatly appreciated! thank you
> JF
*Andrew DeMerchant*
*Computer Technologist*
ph.1-877-4GEMTEC x.163
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
Fredericton, NB, Canada
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide-users
