[mapguide-users] Buffer
Walt Welton-Lair
walt.welton-lair at autodesk.com
Thu Aug 17 09:34:28 EDT 2006
You should look at the sample code in buffer.php (under the mapviewerphp
folder). It creates a buffer layer from the selection.
_____
Sent: Thursday, August 17, 2006 9:22 AM
Subject: [mapguide-users] Buffer
How can I create a buffer with code, when I have the Id's of the object
that need to be selected?
So steps would be:
1. select the objects with the id's received (through parameters)
and De-select previously selected objects.
2. set fill style color and buffer width
3. create buffer
Anybody that can help get this going?
Willem
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060817/19dca622/attachment.html
More information about the Mapguide-users
