javaviewersample shows jsp source
Axel Gross
axel.gross at iaeste.at
Fri Aug 18 11:28:20 EDT 2006
Hi!
I got a problem getting started with mapguide.
I tried to run the sample application for jsp, but
http://localhost:8008/mapguide/javaviewersample/ajaxtiledviewersample.jsp
gives just plain jsp source back instead of processing.
Also
http://localhost:8008/mapguide/mapviewerjava/ajaxviewer.jsp?WEBLAYOUT=Library%3a%2f%2fSamples%2fSheboygan%2fLayouts%2fSheboyganJsp.WebLayout
doesn't work completely as expected. In the right frame the task jsp also
are not rendered.
Jsp in general seems to work though, as the ajaxviewer.jsp response is okay.
hope you can help me getting it started.
thanks,
Axel
More information about the Mapguide-users
