Dynamically Adding Layers to a Map with Selectable Features
    Scott Reisdorf
    reisdorf1 at llnl.gov
    Fri Aug 18 12:18:26 EDT 2006
I am dynamically adding layers to my Map object, and would like the Map
to have the Features selected after the layer is loaded.
I have followed the DevGuide examples, and I get the new layers to
appear; however, the features on the layer are not selectable.  Looking
into the base Map definition, I see that when a layer is added that can
be selected, additional XML nodes are added to the map as below, with
the 'Selectable == true'.
    <MapLayer>
      <Name>New Layer</Name>
      <ResourceId>Library://.... </ResourceId>
      *<Selectable>true</Selectable>*
      <ShowInLegend>true</ShowInLegend>
      <LegendLabel>   </LegendLabel>
      <ExpandInLegend>true</ExpandInLegend>
      <Visible>true</Visible>
      <Group></Group>
    </MapLayer>
If I want my dynamic layers to be selectable, do I need to also update
the base Map Definition file too, or is there some other way via the API
that I can do this and have the new layer features be selectable.
Thanks,
-scott
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060818/a41204c0/attachment.html
More information about the Mapguide-users
